Urgent advice reqd! | on ElectriciansForums
Discuss Urgent advice reqd! in the Australia area at ElectriciansForums.net
M
mk1vanman
hello there! first post! Well here i go, basically i have a spark in my house doing work for the plumbing company i have in fitting a new en suite for me, the house has an old style consumer unit, not rcd protected, but has one of these little rcd units for a shower that was put in by the previous owner, think its a 40amp breaker!? anyway, this spark plans to add another of these units for the new shower in the en suite, dont know why but somthing tells me this isnt right!? i could be wrong as i am no spark! ive had a look at where the tails are and where they go in, the out going tails for this little rcd shower unit leave which is fine, but surley there isnt room for yet another set of cables for the new shower breaker??
Please forgive if my terminology isnt great ive tried to describe it as best as i possibly can, really hoope the response will be "dont worry it sounds ok" but somthing just dosent sound correct here!!
any help/advice would be great folks! thank you!:)
Is he registered under a competant person scheme ie NICEIC NAPPIT or ELECSA. Does he intend to provide certification and notification under local building control Part P. ?? You need YES answers to both questions.
If so thats a good start, as said if he is supplying certificates for the work and also registering the works under labc which if nic registered he should, then as far as can be seen you should be fine. The fact he is putting rcd protection to your new shower is the way to go, seems ok on the info your providing.Obviously not seeing the work and going by what you say limits a more accurate opinion but as said seems ok.
Don't qoute me here but hasn't 17th edition altered on rcd's for bathrooms...they have to be installed now on certain circuits if i recall correct on info i have been told..?...bathrooms are a lot more strict now..
just texted my plumber and he said that the spark is providing certs and is notifing the correct persons, maybe its just me, just didn't think it would look correct with 3 sets of cables comin out of there!?
A bit more info would be helpful, as, on principle, it could still be done safely enough as you describe it if the terminals have enough capacity. Henley blocks would be an obvious alternative, but maybe they`re not strictly necessary. We can`t see it so you`d have to do the eyeballing stuff.
Assuming the tails from the meter run unbroken to existing CU, where exactly has he tapped off the feeds for these additional RCD units?
Cable size of feeds to RCD units?
It sounds fine to me.
The only thing you need to make sure is that all the circuits in a bathroom must now be RCD protected, including the lighting.
having said that, maybe ask him for a quote to upgrade your CU.
That way all the circuits will be in one CU with no need for additional for the showers
tails from the meter run unbroken to existing CU, he has tapped of from where the tails come from the meter side as far as i remember, and the Cable size of feeds to RCD units seem to be same size as the tails,hence the lack of space i presumed!? hope this helps folks!
The replies your recieving are of a positive nature ans I feel likewise. I think you can sleep easy generally speaking. If the guy is NICEIC registered there is a good bet all is good. Also at least he answers to a respected governing body. Its the one's that are't answerable you need to worry about.
Sleep easy my friend. :);)
guys within around twenty mins my questions have been answered perfectly, thank you all for your advice, its been great! ill definately sleep better tonight!:D
To be totally honest pal, just fork out the money to replace your old CU for a new one, then everything will be RCD protected and you can sleep at night knowing you're completely protected because as someone said earlier, as well as your shower's, if the supplementary bonding isn't in place then all circuits supplying the bathroom need to be RCD protected providing the main bonding is in place and up to regs.
All future work will also need RCD protecting under the 17th ed so a new CU will be worth it in the long run!!!
Are you saying he has the new shower connected before the CU? If this is the case and your whole installation exceeds the rating on the suppliers protection device then you will be paying out each time the suppliers fuse blows around ÂŁ50 a time
yes i thinkso, his tails for this little rcd unit for the shower are not connected into the CU at all, they are into the bit where the main tails come in! so this isnt correct now??
Reply to Urgent advice reqd! in the Australia area at ElectriciansForums.net
M
Advice needed for fitting shower door frame? Hi, We're currently adding an en-suite to a downstairs bedroom, everything is going well so far...
Monster
M
J
Have my water pipes been plumbed the wrong way? Good morning, I recently had an extension, new bathroom and new en-suite fitted. Prior to the...
jennys07
J
