M
m25maintenance
its a gravity pumped system. i have a seimens rwb2e timer and iv mixed the wires. from the fcu there are two twe wires on the load side. on the timer there is L N 1 2 3 4 SO ON CABLE ONE THE LINE WIRE GOES TO L BUT THE BLACK WIRE ON THAT CABLE DONT GO TO THE NEUTRAL IT GOES TO NUMBER 2 R 3 BECAUSE THE NEUTRAL IC CONNECTED FROM THE OTHER RETURNING CABLE. IM NOT EXPLAINING VERY WELL. OK 2 CABLES FROM THE LOAD SIDE OF TH FCU. BOTH CONNECTED TO TIMER BUT NOT SURE HOW. ARRRRRRRRHHHHH
