urgent problem !!! | on ElectriciansForums
Discuss urgent problem !!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
waitees
hi all
got a bit of a problem got a assesment on tuesday with the niceic , got a cancellation assesment as i had nearly finished second job. th problem is the gas is bonded however i cannot locate the incoming water supply, its a massive victorian house, there is a 10mm earth cable coming from under the floor boards and i am getting continuity on the water pipes, so it is bonded somewhere. however i cannot confirm its 600mm from incoming or where it is, do you think he will fail me or do i write on the certicate unable to locate and this is ok ?
please help :confused:
What is the scope of the work you have done there???
Ideally clamp needs to accessible for inspection.
Are you able to run new MPB in??
why not play clever and tell the examiner that its bonded under flooring that you lifted then replaced but customer dont want you to lift again?? ;)
sorry mate not sure what mpb is, all the floors are solid and they have had a new extension a couple of years ago the old kitchen has all new cupboards and it must be located behind one of them but its impossible to dismantle, not a clue what to do !
new board has been fitted
what work have you done?? new fuse box!??
as long as you have proved continuity on water i would not be worried to much as you cant be expected to rip apart customers houses to put a tick in the box if you follow!! if your happy that its the water bonding and its doing the job tick the box
i did a house about 9 months ago where main feed was in the wall..! only thing showing was isolation co-ck head sticking from concrete
we bonded the nearest bit of copper that went to the cold water under kitchen sink! it was further that 600mm but it was only accessible part..! you got to follow common sense some times as the regs were written in the perfect world by perfect lawyers sat in perfect offices not day to day sparks!!
thanks for the responses, i have changed the cu from two really old boards to one 15 way 17th board. use the the r2 wander lead and got a reading. if i was to use this as continuity what sort of readinfg would be acceptable?
think im inclined to disagree on this one,
a high importance is placed on bonding conductors and for the right reason.
i could ignore this situation , but if you were prepared to ignore for an assesment then what would you do on jobs that werent being assesed.
(not aimed at you in particular just at the situation and another opinion)
at the least (if no time to correct) i would admit to it and say that it is to be corrected or cannot be but dont try sweep under carpet. although having said depends on what the assesor is like and cosidering the standards turned out by a lot then i dont suppose it would matter if you never fitted any bonds in the first place.
usual acceptable read is 0.05 although its more about proving cont exists than the reading itself
think im missing an s in assesment, assessment yup think i am, my spellings worse than my math ;)
bit confused on what to do in this situation as its a first that i am unable to locate. i do agree with the last response time should should be set aside to locate these things however i also agree with another response it really should also take in to account common sense. the customer is not really wanting me to pull all the cupboards apart to locate this bonding. its not at all old and it might not even be located in there, god knows where it is !
i am getting a reading on the water so it is bonded, i think i will just be honest and tell the niceic man that i have taken these measurements and explain situation and see what happens.
honesty is the best policy, and i am a crap liar :D
hi all
Have a read of 544.1.2 page 135 of BRB "Where practicable the connection shall be made within 600mm"
Remember that reg for your assessement as the others have said no one expects you to tear the house apart to find it. If you can prove continuity and get a reading below 0.05 as recommended by guidance note 3 I think you would be home and dry. Its all about safety and safe procedures.
Good luck
Chris
theres also a good chance he wont menton bonding, he got a huge area to cover and cant ask you everything, as long as you have a reasonable answer for anythng he throws at you
Reply to urgent problem !!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
