Usage metering on machines | on ElectriciansForums
Discuss Usage metering on machines in the Talk Electrician area at ElectriciansForums.net
JSSE
North Lincs
We have a complicated site with over 14 electricity and gas meters.
We have 4 major machines and would like to start with them and install Kw metering along with an hour meter connected to a running signal from each machine.
This would give us Total consumption, hours in actual production and the hours spent idle.
Think they need data for job costing, to arrive at a figure for costings.
Preference would modbus/IP/Radio connected to read remotely and collect data.
Have looked at some socomec stuff online but was wondering if any one have done similar.
Cheers lads and Girlies
Reply to Usage metering on machines in the Talk Electrician area at ElectriciansForums.net
It sounds like the company involved in the works doesn't have the necessary expertise to undertake the task A company that specialises in this...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
