usb charger sockets | on ElectriciansForums
Discuss usb charger sockets in the Electrical Tools and Products area at ElectriciansForums.net
Exeter area
Anyone fitted these new sockets with integral usb charger slots? I've found you have to disconnect a supply wire when doing IR test.. might seem obvious with hindsight but caught me out the first time :dunce2:
Fitted a masterplug one from wickes in my house other week, it said in the destructions you could IR them and they even state the reading it should give, but leaving them connected will give you misleading results anyway.
Don't see how you can IR test them connected.. Does the transformer magically disconnect for the test? Or maybe they were designed by VW?
Still dont understand these, how do you charge your device when away from home, not in the same room as the USB socket, what happens when the USB socket stops working. Also I believe there is no BS at the minute for the USB socket!
Instructions......
  • [ElectriciansForums.net] usb charger sockets
So if there was another fault elsewhere on the circuit of say 1milli ohm or more, the reading of the socket would mask it as the tester would record the lowest reading of 0.4mohm!? The lowest acceptable reading is 1 Megohm!! And it doesn't say across which wires either..
The lowest acceptable is 2 IMHO
I would presume it would give this reading between L and N like other connected loads, neons etc etc still connected on circuit. So obviously would need disconnected to achieve accurate results, unless you are doing eicr etc where you can get away with testing to earth only in most cases
Personally I wouldn't install the combined units , I would go down the route of a switched fused spur feeding a stand alone USB socket if I were asked , but haven't been asked yet myself..
This has already been discussed in depth on here, approx Dec 2014. Do a search on the forum as there are some links to various independent test companies with surprising results and some good info as well.
For the time being I am not touching them.
Reply to usb charger sockets in the Electrical Tools and Products area at ElectriciansForums.net
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
