USB sockets and IR testing help... | on ElectriciansForums
Discuss USB sockets and IR testing help... in the UK Electrical Forum area at ElectriciansForums.net
Merseyside
Hi all,
I have seen somewhere recently that one particular brand of USB socket is good for 500v for IR testing, but I can't now remember where or which brand. Is this now the standard for these things? Has anyone come across any brands which are ok to do this on? Help appreciated...
It should also be noted that the electronic circuitry inside the SMPS could easily be damaged by a 500 V insulation test injected across it. Consequently the USB port may fail to function following a 500 V Line to Neutral insulation test.
British General. Fitted one last week, checked instructions... good to 500v, will result in 10 mega ohm reading (I'm guessing between line and neutral).
I say that because I only did LN to E (other gear on the circuit) and was getting in excess of 400 mega ohm.
Thank you beginning to think I was going mad !
Personally, I remove the sockets and bypass with wago connectors. I don’t like it but I do like the readings! I think these damn things should have an isolator built in (operated from the front with a screwdriver) that disconnects the electronics. Where’s a good BS standard when you need one!
Reply to USB sockets and IR testing help... in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
