usb wall outlet | on ElectriciansForums
Discuss usb wall outlet in the UK Electrical Forum area at ElectriciansForums.net
G
gavinwr
I want to know if there are any usb wall plates with no socket outlet and normal terminations because the ones i have found have only got the usb and 4 pins sticking out of it and i dont want to solder and i cant work out how to wire it for power anyway
what i am trying to do is wire up this port above where i keep my electricals so i can charge them without bulky plugs in the way i dont want it connected to the computer (do i need a transformer)
you can get wall sockets with a USB connector on them that only does charging, I don't like them though, there's the ones that look like a plug but with no flex/wire and you just shove the USB device in to charge as well....plates with just a USB charger in them are not available as far as I know....apart from custom Dado rail units for retail display stands
im not looking for anything with normal sockets as i have wired up a socket next to where i will put it all i would like to so is put a spur from the socket to the usb socket
Reply to usb wall outlet in the UK Electrical Forum area at ElectriciansForums.net
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
