L
lucky67
Ok sure I'm going to be flamed for this but...
I'm using polystyrene sheet to insulate a wall in a room in the eaves...
I have a few PVC power cables that I will have to move (I've read that polystyrene causes the PVC to become brittle)...most of them are for the 2 lights in there but there are 2 that I have no idea what they are....
Now I was going to run them through some type of plastic conduit ...but then I read that that might cause problems too...so my next solution was to attach a piece of wood/plasterboard to the top of the polystyrene and then cable clip the cables to this...(so they run where they do now just 75 mm or so further off the wall)...
The only problem would be where the unidentified cables disappear through a hole into a plasterboard cavity - I'm looking for something to line this hole with to keep the cable from touching the polystyrene -plasterboard or wood would be a nightmare to cut and fit to line such a small gap so I was thinking that maybe I could use a piece of a milk carton (HDPE) or my other thought was a cut down piece of waste water pipe...
any thoughts???
Also if I do end up using plasterboard/wood to make a tunnel - would it be really bad to stick a little bit of mineral wool in there to stop the draughts?
any thoughts???
