Use multimeter to short io | on ElectriciansForums
Discuss Use multimeter to short io in the UK Electrical Forum area at ElectriciansForums.net
Davey1988
Hello guys
On a 24v circuit i use a link between lots of io to test inputs.
Can i use the multimeter to short the terminals like a link (copper wire) if so what setting would be best. I know boltage reading doesnt act like a short. But not sure to try anything else encase i break the thing lol
Never used a multimeter todo this before. Only to read voltage lol
If this is a SCADA system or similar you can use some voltage verification units to put a 4k ohm load across the inputs. If it is a common mode input you can tie one end down to the common and run through all the inputs very quickly.
It also safe in case you accidentally catch the probe on a supply terminal.
Reply to Use multimeter to short io in the UK Electrical Forum area at ElectriciansForums.net
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
