Use of cpc as a live conductor - EICR Coding | on ElectriciansForums
Discuss Use of cpc as a live conductor - EICR Coding in the UK Electrical Forum area at ElectriciansForums.net
L
LlandrilloSpark
Fella's
I'm just writing up an EICR from last month, one of the findings was a lighting circuit on the non RCD side of the board where the cpc was used as a strapper in 2 way light switching, Ive marked it as C2 for two reasons, one being that there is no longer a cpc in the cable and also that the no live conductor has no proper insulation, however I couldnt find where on the EICR inspection schedule that it would go?
closest i could find on NAPIT EICR was condition of live parts?
Any help would be appriciated
cheers
Go on then Biff....hit me
i'll just get my trusty knuckleduster.
however , surprisingly , there is absolutely no requirement for a cable to contain a cpc just for the sake of protecting it , which is never guarrented anyway with t&e as you can nail through the live and not touch N or E.
but your on the right track with insulation - and lack of phase identification during the full run.
How about this one we found today........................... [ElectriciansForums.net] Use of cpc as a live conductor - EICR Coding...........great way to earth a light fitting lol
Reply to Use of cpc as a live conductor - EICR Coding in the UK Electrical Forum area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
