R
rsmck
I have a bit of an unusual requirement. I do a lot of work as a theatre technician and am planning on wiring the lighting of our lounge back to a "dimmer pack" to enable "scenes" in much the same way as a Lutron or similar system at a fraction of the cost.
There will be 4 circuits - (ceiling light, 2x 5A sockets for lamps, 2x circuits for wall lights). The dimmer will be protected by a 30mA RCD and each individual circuit is protected by an MCB on the dimmer. The requirements of the 17th edition regarding RCD protection for cables behind walls are satisfied.
Most dimmers have socketed outputs - therefore these (hard wired) sockets and fittings should terminate in plugs beside the dimmer pack - normally theatrical lighting is on HO7RNF cable.
Two questions;
Is it acceptable to use H07RNF TRS cable in place of T&E from the socket / light fitting back to the dimmer (I'm thinking it's not - but please correct me if I'm wrong)
If, as I expect, T&E must be used what would your preferred way be of joining these to flexible tails (I would't put a plug on the end of T&E ) - previously i've seen it done with simple connector blocks in an enclosure but this would be frowned upon under the new regs
Two questions;
