I added an additionl socket to the existing ring in a block of flats the other day and there was no seperate earth conductor,the conduit was acting as it. I moved the circuit to a new consumer unit so the ring was now protected by a RCD. When it comes to filling out the test schedule what do I enter in the R1+R2 column. I assume you enter NAis this correct and if not whats the next move.
