using a metrel MI 3125 query... | on ElectriciansForums
Discuss using a metrel MI 3125 query... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bobby101
hi all i been using the metrel test meter with pre programmed Zs tables in it but i was wondering why when testing a BS 1361 fuse the table only goes to 30amp rating (0.4 disconnection time) and not allowing me to test the higher rated BS 1361 fuses (5 second disconnection time) is this a issue i should talk to metrel about or what i know its easy enough to check regs book table 41.4 for ref but just seems annoying anyone from metrel care to comment
I cant help with this but as you been using this kit and I have just bought one with out checking what it can do, can you let me know if it can do a Ze and PSSC, PFC test? thanks
Reply to using a metrel MI 3125 query... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
