Using an outdoor light via normal 3 pin plug? | on ElectriciansForums
Discuss Using an outdoor light via normal 3 pin plug? in the UK Electrical Forum area at ElectriciansForums.net
cable_guy
Hi all,
I'm not an electrician, I come here for advice.
I wondered if it would be possible and safe to run a long, thick, armoured cable from my outdoor plug on my conservatory underground around 20 metres to power an outdoor light?
Or would I need a full new circuit ran from my consumer unit
thanks in advance.
Hi all,
thanks in advance.
Are your sockets RCD protected? is the new light a standard type? or fixed to the wall of your house? 3 questions sorry sounds like it is going to be remote forgot the 20Mts bit
Reply to Using an outdoor light via normal 3 pin plug? in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
