vbyrne
Lads, any good advice on how to use the BGB for the 17th exam.
Discuss Using BS7671 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You gotta admit, that was a good answer.Yep. Read it first.
hang on a min so being an open book exam its still too difficult so its multiple choice as well?Without wishing to cause offence to someone.....are you serious?? The 17th had got to be the most pee-take of exams going. You've got something like 4mins per question to look the answer up out of the book from the four possible options on the screen in front of you. My missus could do it. Come on. If this lad can't make the grade and he's even doing mocks, then maybe he's made the wrong career choice.
me? i havent done am2 yet.:willy_nillyon't you know then didn't you do it
I know, I know, when I done the exam I used some tabs I explained this to the lad but it seems like he doesn't like doing this he thinks that it should be done with out the use of these colour sticky things hanging out of the book I found it helpful but there you go I thought that someone out there had a better systemWithout wishing to cause offence to someone.....are you serious?? The 17th had got to be the most pee-take of exams going. You've got something like 4mins per question to look the answer up out of the book from the four possible options on the screen in front of you. My missus could do it. Come on. If this lad can't make the grade and he's even doing mocks, then maybe he's made the wrong career choice.
use the index mate, makes life quicker
It gets worse mate, you can often discount 2 of the 4 choices immediately if you have half a brain so you've got a 50/50 chance of hitting luckyhang on a min so being an open book exam its still too difficult so its multiple choice as well?
Reply to Using BS7671 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
