using conduits as cpc | on ElectriciansForums
Discuss using conduits as cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sams
Hi everyone and thanks in advance.
I am doing PIR tomorrow and I have been told by another spark who saw the job that conduit is used as a cpc, is that acceptable providing the readings:confused: are ok .
Absolutely fine. Rigid metal conduit and the metal sheath or armour of a cable can be used as a protective conductor. 543.2.2, 543.2.5
This install will need a very thorough visual and continuity test on all the metal parts. If you find any defects, then quote to put in a cpc to back up the protection from the conduit etc.
Cheers..........Howard
Reply to using conduits as cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi just wondering if anyone knows of any other software. I have been using tradify for the last few months and it has been quite useful for...
Thanks guys, I ran UF-B. Never handled 6/2 before, wasn't as difficult as I expected.
