Using CPC as live conductor.... ok i know, but... | on ElectriciansForums
Discuss Using CPC as live conductor.... ok i know, but... in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Had to change a bathroom fan at the weekend for someone and they wanted it to be on a timer, but couldnt as the cable was buried in the wall and wouldn't move etc..
the cable that fed it was a three core flex, I the earth was not being used anyway due to the load on the end etc.
I know you are not meant to use the CPC as a live conductor, but if its flex and the same CSA and you were to correctly identify it with brown etc, would it have then been acceptable?
I didn't do it, but it made me think, oh i so could have used it, but it just seemed wrong. I can understand why you wouldn't do it in twin and earth, but surely where its flex or all conductors are the same CSA and have their own sheathing on them inside the outer, would it have been acceptable or not?
I am going to say not on the basis CPC is CPC and nothing else, any thoughts would been welcomed.
Simonslimline and uksparks feel to buy a copy of this book and read it sometime rather than listen to the NIC or any other CPS.
[ElectriciansForums.net] Using CPC as live conductor.... ok i know, but...
- - - Updated - - -
Yes i am aware of that... i was simply mentioning what i had read :)
I read in the beano you can fall along way off a high cliff and walk away unhurt, does it make it true?
I am trainee and do own BS7671, if you read my post it does say that the NIC make it up as they see fit. I mentioned it only as i remember reading about it a while back.
- - - Updated - - -
Well then you need to read it, threads like this will help you understand it more. Only say something you have read by providing a link to it to prove your point.
I remember a story going round a while back (90s) about a plumber who cut into an existing boiler wiring flex that had cpc as live - can't remember details but he connected the cpc to earth term somewhere in his jb and result was fatal shock for homeowner off the kitchen sink.
Reply to Using CPC as live conductor.... ok i know, but... in the UK Electrical Forum area at ElectriciansForums.net
It's the same with any system, if you put poo in, you get poo out!
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
