Discuss Using double pole RCD in the UK Electrical Forum area at ElectriciansForums.net
Thanks guys in advanceIs there anything preventing us from using these type of RCDs for a 55-0-55 circuit?
the picture shows the original set up.
Yeah it’s trace heating on pipe workHave you looked closely at what the original setup actually is, that you are suggesting replacing with just an RCD?
Does the same thing though.Thats a double pole MCB and a shunt RCD so no the above is not compatible
Sorry my error wasn't paying attention ?A rcbo would not that RCD
Reply to Using double pole RCD in the UK Electrical Forum area at ElectriciansForums.net
