Hi,
I’m replacing the two lights in my living room (both ceiling rose pendants) with flush fit lights, so was looking at using the Hager J804 junction box (I have access under the floor above light fittings). Both lights are operate by a single switch. The ceiling rose has no Loop out. My question is can I wire the J804 as i’ve drawn, with two light cables coming out of the junction box? Or can I only wire one light cable from the junction box? Also should I use flex running from the junction box to the light fittings as opposed to T&E? The second light fitting is about 2m away from the first light fitting where the junction box will be.
Hope this makes sense!
Cheers
Josh
Cheers
Josh
