Using installation tester for pat testing? | on ElectriciansForums
Discuss Using installation tester for pat testing? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Does anyone use their installation tester with an adaptor ( unsure of proper name) to allow you to use it as a pat tester?
Is this a lot of hassle or is it quite straight forward?
Which is a good adaptor?
Cheers
The basic Pat tests can be carried out with a 17th edition multifunction tester. Carry out an Earth Continuity test, followed by an Insulation resistance test at 500v L and N combined to earth. But a Pat tester will usually do a lot more.
Cheers...........Howard
It's a while since I did any PAT testing, but I seem to recall the earth continuity test involves a current of 25 A to "blow" any connections which are hanging on by just a couple of strands.
Reply to Using installation tester for pat testing? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
