simopesh
It can be done. See pictures.
Where's your modding sensibilities, guys?! I want to know how that works...... I have plenty of knackered tools with great batteries, and good tools with knackered batteries, getting them to fit this way would be tidy. Also, would be cool to get three or four lithiums that fit all your tools with various 'adaptors' for all your tools.
Is that just the shell of the dewalt battery, wired to the makita clip diretly so it fits, then? I like it!
Yes, it is. All that you need is a knackered battery holder and an empty shell. Then you cut it, clean it with sand paper and then glue it with solvent cement. Make sure that the positive and negative are correct in case you want to use the Dewalt charger as well.
[video=youtube;39unmJWigmA]http://www.youtube.com/watch?v=39unmJWigmA[/video]
now that a cool solutIon E-bay spares or repairs for makita holders then
you should make a video of how its done.
Well, my Makita SDS packed up after 2 years of heavy duty use so I was left with two healthy batteries that I wanted to put into good use.
Currently I haven’t got a body and faulty battery to use in order to create a clip.
tell you what the drills are bulky enough sometimes never mind extra bits hanging off them in a cupboard, think i will stick to the standard batts.
phil does have a point, wonder if theres a way of slimming it down? still a good solutIon though.
maybe an umbilical cord type thing like you can do to the makita batts so they clip onto the belt rather than the drill. makes it real light and easier to work with
I thought about it though. It is like the power supply to the cameras flash in the past with a flex curly wire.
Yea that would just be better anyway even if you were using the original batts, and should be well easy to knock up. I may have a look at that....
I guess that would boil down to how often you would be switching tools or had to put the machine down but unclipping would still be easier and safer than a trailing cable.
Hi chaps,
I just made another one. (Well, not fully finished though) My mate had a few Ryobi batteries 2.4 amp Li-on and recently changed to Dewalt.
There are a few pictures of almost exactly what is done and tools/materials needed.
some werid and wonderful things you find on here! personally if id took the time gutt the orginal battery i would just buy some new cells and fix the orginal battery. You can get the cells used in nimh dewalts for about a £0.75pence if brought in bulk.
My mod that i did to my dewalt 36v flash light was pretty sweet, i brought the best led i could find a 700lm luxeon rebel tri-star from America and fitted it to the snake torch with a cpu heatsink the torch lasted for about 35hrs and brighter than the orginal. It was that good that someone nicked it. I was gutted i spend a fair few evenings doing it!
Well, after a year since I build the adaptor I have found some extra benefits. Makita Li-on batteries tend to fault on a regular basis and are practically impossible to get charged again by the Makita charger.
Guess what, I can recharge any faulty Makita battery with my adaptor and a Dewalt charger! :D:D:D
Using Makita Li-on batteries on Dewalt body.
Electrical Tools and Products
simopesh,
wallyking,
