Using manual transfer switch to distribute power | on ElectriciansForums
Discuss Using manual transfer switch to distribute power in the DIY Electrical Advice area at ElectriciansForums.net
Missouri, USA
The application is providing AC to a camper. The goal is to provide AC input to charge a solar 'generator' when the camper is connected to shore power. Then, when the camper is disconnected from shore power the transfer switch is moved to Position #2 for the solar generator to provide AC power to the camper. To accomplish this goal I tap into the camper's existing distribution panel bus bars.
  1. When the manual transfer switch is in position #1
    a. Shore power is routed to a Jackery solar generator. The Jackery is limited to a 15 amp AC input, which is the reason for the breaker.
    b. AC output from the Jackery is disconnected.
    Note: AC output from the Jackery is off by default. A button on the unit must be pressed to turn on AC output.
  2. When the manual transfer switch is in position #2
    a. AC input to the Jackery is disconnected.
    b. Power is routed to the camper's distribution panel from the Jackery's AC output.
    Note: The circuit breaker is needed here, but I provided it as an additional cutoff.
  3. When the manual transfer switch is in position #0
    a. The Jackery is isolated from the circuit.
  4. Note: There are positions still available on the transfer switch. I intend to use a couple in Position #2 for some DC distribution that is completely isolated from the AC distribution.
Is this wiring correct? If not, what corrections do I need to make?
Thank you,
Andrew
[ElectriciansForums.net] Using manual transfer switch to distribute power
Reply to Using manual transfer switch to distribute power in the DIY Electrical Advice area at ElectriciansForums.net
Thank you. I looked further into transfer switches and that will indeed work for me, and I'll only need one. Perfect. Thanks again.
A searh of the manual for the inverter does not return any content for "ground". I do not find any pertinent reference in the table of contents.
