I have recently come across a situation whereby instead of running a main equipotential bonding conductor from the MET to the incoming water someone had instead ran a short bond from the MET to some copper pipe in the mains cupboard and clamped it and then placed a bond on the pipe near the incoming water (at the other end of the property) and bonded to the incoming water there.
Wander lead method states 0.02 ohms resistance.
I know this is not good practice but where does it say in the regs it has to be a continuous conductor and that you can't do it.
