J
Jeff105
I have just bought an Innuos music server not realising it has no built in Wi-fi capability, but needs an ethernet wired connection to the router. This could be done only by placing it in the cupboard where the router lives, whereas I wanted to place it alongside my Naim streamer upstairs. So the manufacturer suggests using a couple of powerline homeplugs.
Looking at some advice pages on the net I have tried to clarify if this will work across separate power circuits. Downstairs has two separate mains rings, with a third mains ring upstairs. These are all fed via RCBOs from the same consumer unit and meter supply. Some say they will only work if they are on the same circuit, others that they will work across several circuits from the same supply.
Can anyone advise please?
