Using solar panels to power swimspa on a separate fuse box | on ElectriciansForums
Discuss Using solar panels to power swimspa on a separate fuse box in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
Twebbo
Hi,
Hoping for some help. We have existing solar panels on our roof and recently had batteries installed to charge from the panels. They are both connected to an indoor fuse box.
The main purpose of the batteries was to store solar energy captured and then use it for heating our outdoor swimspa (which uses a tone of electricity.
Unfortunately this isn't happening - the batteries are charging and any electricity used in the home is drawing from them.
But the spa is on a fusebox in the garage, and is not drawing from the batteries (and nor is it using the solar energy direct from the panels as it is produced).
Is there a way for the batteries (and panels) to power both in home use and the swimspa if they are on different fuse boxes?
Many thanks in advance!
Reply to Using solar panels to power swimspa on a separate fuse box in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
I am living in the north of Thailand where the grid is very unreliable (rainy season outages multiple times per week or once a full week). I...
