The trouble with soldered joints is they dont really have a raited current! A bit of oil/ crap on the joint and it may look ok but wont draw any current. Do you lay the conductors end to end? or side by side? If side by side do we solder a one inch joint or longer? whats the current carrying capacity of 2 x 2.5mm solid core conductors soldered side by side an inch long?? Does it allow greater current carrying capacity if layed 2" side by side and soldered? What if theres crap in the joint? do we derate the joint by X factor??
Block or conector, solder and theres two many varibles.. (A Electronics hobiest (i know a dry joint when i see one))
Making a solder joint with solder alone is a no..no..
electrician's solder goes soft at 160 deg C, which means under a fault condition it may melt at that instant and fall apart,
We were taught to loop the two conductors to be joined and then either pinch or twist the ends, then solder. You are now guaranteed that when the solder melts, if it does, your joint won't fall apart......
