Discuss Uvr???? in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi guys im on a job, its a new build studio flats and in the main panel were all the boards come back to it has 2 wires with "uvr" on them and not going anywere? Any ideas what this stands for and were it goes?????
Thanks for your time
Thank you very much matey.....
Reply to Uvr???? in the Electrician Talk | All Countries area at ElectriciansForums.net
I also don't see the need for switch-fuses after the Ryefield - typically each flat will have a cut-out with a solid link for local (i.e. sparky...
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
Yeh… about 3 quid for a new switch…
But I think there’s too many wires there for you to attempt to change it yourself
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
looks like the OP has disappeared which is a shame, would be nice to get to the bottom of this.
