Vacuum and compressor automation | on ElectriciansForums
Discuss Vacuum and compressor automation in the Talk Electrician area at ElectriciansForums.net
South africa
I've been asked to design a panel for 2x 3phase comressors and 2x 3phase vacuum pumps.
Non of the motors can start at the same time and between the 2, they have to run alternately. The vacuum pumps need to be wired so that if more vacuum is needed the other will start. Keep in mind that when the system is not being used the pumps will work alternately....
TIA
I'm asking for help on what i need to design this panel. To make them work alrernatly I can use a "flip flop relay". How do I incorporate the vacuum pumps to work alternately as well as standby if one cannot cope with what is required?
What I meant was after it has been used.... before it is used again. They use the vacuum and pressure for different reasons in the lab. If they start at the same time the current spike is very high.
So what you are saying if the compressors are running the vacuum pumps cannot start and visa versa. With the vacuum pumps only one can be started initially but there is a facility for the second to kick in if required.
Yes, but after each cycle the vacuum pumps will start alternatively. So vacuum 1 will start and if required vacuum 2 will start. The next time vacuum is required vacuum 2 will start and if more vacuum is needed then vacuum 1 will start
I think, knowing the use the vacuum is going to be for could help.
Is the vacuum to be used as fume extract?
Is it to vacuum liquid, will there be a catch tank?
Is it to be distributed?
Is it for a delivery system?
Is it to hold something in place?
Is it to be used for vacuum packaging?
Rob - I can see the need for compliance with EN60204-1 but if he built the system, bit of a long shot from what we've seen thus far, with ce marked products is there further requirement for ce certification?
I've never heard of the necessity for logic system built with a plc or a few relays.
Yes anything built like that needs to fill CE requirments.
Not got time into going over it now but take a look at this:
Conformity assessment - Work equipment and machinery - http://www.hse.gov.uk/work-equipment-machinery/conformity.htm
I'm still surprised because I know that people who custom build control panels have too but you can buy ce marked push button assemblies etc.
I know someone who installs siemens gear, check out there sirius range to see what I'm talking about, and he never mentioned it when we chatted about the technicalities of the subject nor was there any comments on the siemens forums.
I posted a question on there forum so I guess I'll see soon.
Reply to Vacuum and compressor automation in the Talk Electrician area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
I have sent you my contact details where in the West Midlands are you? I am based north of coventry but travel the county and beyond you may...
