Discuss Vaillant advert Is it possible? in the Central Heating Systems area at ElectriciansForums.net
You ain't thinking of installing your own boiler, is ya?
It is possible then if the cold water feed and gas was available?They would have to go straight through the wall for that boiler in the picture - I wire enough of the blessed things up!
7...Flow, return, gas, cold water, hot water, pressure relief valve and condense pipe.It is possible then if the cold water feed and gas was available?
Can’t imagine how many pipes are on the other side of the wall though.
I guess then, one would not really like 7 pipes over the counter/sink cupboard area.7...Flow, return, gas, cold water, hot water, pressure relief valve and condense pipe.
Reply to Vaillant advert Is it possible? in the Central Heating Systems area at ElectriciansForums.net
