Discuss Vailliant 12KW Air Source Heat Pump hot water problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello people wonder if you can help me I have been called out to a ASHP with intermittent hot water problem. I have changed the relay checked the immersion but still getting it could it be the timer relay ? I am a little bit stuck as we always wire our controls through a danfoss programmer but this company has no programmer on the ASHP controller. Does this mean the hot water is on all the time ? e.g Controlled by the tank stat ? Help would be good
Reply to Vailliant 12KW Air Source Heat Pump hot water problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
These Official Forum Sponsors May Provide Discounts to Regular Forum Members - If you would like to sponsor us then...
Thanks mate, not something I have a lot of experience in. But that makes perfect sense
As per Davesparks, it would be helpful to see a picture of the valve etc.
If the manifold valve referred to is a common or garden motorised...
