Valiant Boiler
O
Octopus
Ok, this may sound a silly question but does anyone know if Valiant boilers use 240v or 12v on their room stats??
The boiler is 6 or 7 years old if that helps!!
Geordie should know this... If he's still awake.
trhink he's on an alcohol diet at the moment.
The last couple I have seen have been 24V. If you have the model number I might have a manual.
I might be wrong but they may have both a 230v next to the mains input and a 12v on the board. But not sure about older models.
Geordie knows that it isn't a Valiant boiler .. it's a Vailant.
https://www.google.co.uk/search?client=opera&q=vailant&sourceid=opera&ie=UTF-8&oe=UTF-8
See if you can find the model number then we can search the Vailant site for the manuals etc.
I have worked on a few Vailants, but not as many as Baxi Worcester & Vokera so I can't be sure.
I seem to remember the old Sine 18 was 240 volt but not 100% sure.
What I DO know about them is they were built like battleships and weighed a ton and could easily last more than 20 years.
The last one I fitted which was a Turbomax??? over 10 years ago & I was disappointed with the build quality of it.
