Valiant with pump inside the boiler ? | on ElectriciansForums
Discuss Valiant with pump inside the boiler ? in the Central Heating Systems area at ElectriciansForums.net
Currently wiring a boiler but the pump is inside the boiler ? My connections in the boiler are L E N RT Im guessing rt is room thermostat? Or have I got confused the boiler is a valiant ecotec plus 637
No manual plumber must have took it with him, so if I wired from the boiler with a 5 core flex, taking L E N that being a permeant live ? from wiring centre then used the black in the 5 core from the oranges on my wiring centre to the RT connection at boiler that should be correct?
Reply to Valiant with pump inside the boiler ? in the Central Heating Systems area at ElectriciansForums.net
yeah, I installed the new one. Last one looked like it had its days, just cut out some cable routes in the back box and connected it up. Yep mate...
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
