Van Pipes | on ElectriciansForums
Discuss Van Pipes in the UK Electrical Forum area at ElectriciansForums.net
DL electrician
Hi Guys,
Been looking into pipe carriers for the new van and wanted to see what some of you have gone for...
As I understand it I would need a plastic liner to minimise marking on plastic trunking etc
Rhino seems to be a popular choice and have just been told it has a coating inside?? Not sure how true it is though! Anyone have a rhino tube?
Cheers
I've managed to get them down to about ÂŁ119 for the Rhino....
It's the access caps for the pipe that seem to be expensive...
Think I'm decided on the Rhino, just need to confirm this lining bit....a few others clearly show a plastic sort of insert? Rhino doesn't but am being told of this 'special coating!'
I have three vans and three rhinos, not once have I ever had a bit of conduit scratched (PVC or galv). If you're that worried then get a 3m length of 100mm x 100mm maxi trunking and slot it inside, it fits rather snug.
One other thing the Rhinos have is crash test approval, you aint gonna get that with a bit of stink pipe. No need to worry about rear ending Mrs 'Baby on board' and spearing the nipper in the back with a 3m length of galv conduit.
I've got nothing but good things to say about the rhinos.
Thanks for your replies mate.
It isn't so much the scratching, it's the reaction between the metal and PVC, apparently a magical occurrence takes place and marks the white PVC trunking/conduit.
But the crash testing is deffo worth it, especially with my driving!
Reply to Van Pipes in the UK Electrical Forum area at ElectriciansForums.net
