Van stickers niceic labels | on ElectriciansForums
Discuss Van stickers niceic labels in the UK Electrical Forum area at ElectriciansForums.net
newfutile
Nearly Esteemed
Supporter
hemel hempstead
Does anyone have any good methods to apply stickers to the van? My niceic labels have arrived so I have to fix them on.
Clean it first.
a good eye and a squeeze to push out any air bubbles and you will be fine.
Are they paying you for free advertising.
I think the idea is that if YOU put THEIR logo on your van, then YOU get more work as people believe you are the best of the best.
I’ve got a Volkswagen badge on my van, and they’re not paying me for advertising.
Clean the van, isopropyl the spot where sign will go. Logo is small so you can hinge it on the top using masking tape, when you happy with the position peal 50mm of the backing off and fold it flat against the sign. Tape will hold the sign in position. All you need to do now is to run your squeeggee from left to right while gently pulling the backing down
After cleaning the area where sticker is to go, I lightly spray with water using an old spray bottle, e.g. windolene bottle. Then sticker can be moved about a bit . When satisfied with the position, hairdryer on low heat dries it out a treat.
Reply to Van stickers niceic labels in the UK Electrical Forum area at ElectriciansForums.net
Yep They try to sell, sell, sell At the last asessment I told the asessor that I used SELECT to update my regs and inspection and testing, on...
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
