Vapour proof flourecent fittings | on ElectriciansForums
Discuss Vapour proof flourecent fittings in the UK Electrical Forum area at ElectriciansForums.net
C
cdmh electrical
Hi can any one tell me is it a regulation in a wood cutting workshop or mechanics garage to have vapour proof fluorescent fittings. Do i right it down on a electrical condition report.
Many thanks
Electrically any accessory should be suitable for the external influences found in the environment, if you have a woodworking shop where there is a lot of dust then the lighting system should be designed such that the build up of dust does not cause a problem for the electrical equipment.
The decision on whether it would be coded in an EICR would be yours as you have seen the situation.
A mention in a covering letter may be advisable, as a recommendation, that dust proof fittings should be used; if a problem is occurring.
Hi can any one tell me is it a regulation in a wood cutting workshop or mechanics garage to have vapour proof fluorescent fittingsBs7671 is never that specific,if you are carrying out EICR's you should have access to Bs7671 and have an understanding of it's contents. Do i right ...write I think you will find it down on a electrical condition report.
Many thanks
A wood cutting workshop or mechanics garage have the possibility of been a zoned area, there should be a drawing of the building detailing any zoned areas, usually just zones 1 or 2. Any electrical equipment in these areas need to be suitable for the environment, ExD or similar.
Reply to Vapour proof flourecent fittings in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
As littlespark says there's no ways you're going to find spike lights that can accomodate SWA cables directly into them.
