varilight v-pro eclique dimmer switches | on ElectriciansForums
Discuss varilight v-pro eclique dimmer switches in the Electrical Tools and Products area at ElectriciansForums.net
Ruislip
These switches look nice but are expensive. I need a 4 gang one and was wondering if anyone knows if the individual modules are replaceable should one stop working in the future or if the whole thing would need replacing. Obviously on their rotary dimmers you can swap the modules out easily for ÂŁ12 each . These 4 gang ecliques cost ÂŁ100 so I'm a bit wary!
I've used the V-pro touch dimmers before and the modules can be replaced - in fact I had one replaced under warranty!. But be careful I found the plastic clips on the modules a bit small which can lead to the dimmer module becoming detached if you are a bit too enthusiastic in pressing the button.
Reply to varilight v-pro eclique dimmer switches in the Electrical Tools and Products area at ElectriciansForums.net
Thanks, it says under the picture of the 4 front plates (in the tiniest writing possible) "Excluding the definity grid pro front plates which do...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
