Vehicle Window Tinting | on ElectriciansForums
Discuss Vehicle Window Tinting in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Amp David
Mentor
Glossop
Looking to get the rear windows tinted on my Astra estate as can't afford a van just yet.
Can anyone recommend a good tinting compamy in the Manchester area that they have used in the past. Want it doing properly and don't want to get a shoddy job done.:eek:
Just a thought have you considered using a bit of the reflective sheeting that works on the same principal as the two way mirror and the wifes hairdryer to get rid of the air bubbles.
Cheap and professional.
Chris
Reply to Vehicle Window Tinting in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
The suggestion from @UNG to use Unistrut inverted is good, as it is 41 x 41 outside or 41 x 21 (I think, from memory) and you can get it without...
It's actually not as those are accidents outside of work, if you suffer an injury whilst working for someone else or doing private work then...
davesparks
