R
roukel01
Hello
I'm having a play with a TDR to find a fault on an underground cable. The piece of kit I'm using is the Megger TDR 2000/2.
I need to put in the Velocity Factor of the cable to be tested which is a 240mm 4 Core Aluminum SWA, the length of run is about 120M.
Anyone have any ideas where I can find or if you know what Velocity factor I should use??
Thanks All.
Thanks All.
