Vent valve greenstar 35cdi compact how to get back inside Hi
Took the vent valve off which has a spring clip and sits in the top right hand side of the boiler, particular to this install it's in a cupboard making access difficult on top of a step ladder and sliding into the cupboard.
I have
Drained the system.
Silicone greased the new valve for reseating
It's difficult to reseat the vent valve and then get the spring insert back into position there must be a technique to get it back in and I don't have it at the moment. The U shaped retainer spring doesn't seem to fit over the vent valve body.
Any help would be welcome.
Many thanks
Matt
Vent valve greenstar 35cdi compact how to get back inside to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
I have
Drained the system.
Many thanks
Matt
