Veritas 8 Compact | on ElectriciansForums
Discuss Veritas 8 Compact in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
York
Hi All,
I've installed a Veritas 8 Compact today, and when it came to carry out the walk test all of the zone lights came on at once.
I have wired it with 1 PIR to each of 6 zones. the remaining two zones are linked out.
I am using a global tamper which is wired in series.
All other tests are OK we have double checked the wiring and it all appears OK.
Also when i go to set the alarm, all zone light come on (excluding the 2 linked out zones) and it wont set.
Do you think its a tamper fault some where and if I link out the tamper would it clear the fault?
Many thanks
Reply to Veritas 8 Compact in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
