Hi,
I purchased a house and the seller gave us the code to silence the alarm and smoke alarm, however it did nothing when the oven set it off.
I attempted to change the pass code but just get a deep beep, i suspect is an error beep.
Also, when attempting to disconnect the integrated doorbell, I removed the alarm fuse and then started to remove the cover and tripped the tamper alarm (indoor sounder). The code did not shut it up, suggesting it is wrong.
I have since found the default code of 1234 and whe I press prog I get a red light on Zone 2. If I then press any code, i.e. 60 I get an error beep.
Is there anything simple to try to at least sort out the code in case it goes off ?
I really dont believe I need it and may rip it out If I could silence the thing.
The wires are all over the shop, including along the bathroom floor under the lino.
Many thanks for looking, any advice would be appreciated.
