Deleted member 124734
Hi, could somebody please give me some advice?
I have a Texecom Veritas R8 alarm. I recently turned off the power for some DIY work, and the external alarm rang until the power turned back on.
I’m aware that this is an issue with the battery, however the alarm usually works fine when power is on.
But, as soon as I turned on the power, the alarm simply rang louder. I tried putting in my PIN, which did nothing; so I tried the default 4321 PIN, which also did nothing, so I tried clicking RESET, which did nothing.
Eventually, the alarm stopped sounding, however, now, the keypad is unresponsive. When I enter the exit zone and the motion sensor goes off, the alarm keypad starts beeping and the Unset button flashes green, until the motion sensor goes off again and this stops.
When I try entering my PIN, a long, deep tone sounds (different than normal) and nothing else happens.
Any idea what I can do to fix this?
View attachment trim.CB122513-4E49-433C-8AF1-218DF3F53441.MOV
- TL;DR
- Alarm will not set after power cut. Keypad beeps when I enter the exit zone. Unresponsive.
