W
Willdd
I have a Veritas alarm fitted with two R8 keypads. One at the front door and one at the back.
I want to remove one of the keypads. This has four wires connected.
Do I simply disconnect the wires and tape up or is there more to it.
Will
your best bet is to get a local alarm guy/electrician to do this simple job. if you get it wrong you could damage the control panel and end up with an expensive repair/replacement cost.
Veritas R8 keypad
Willdd,
Spoon,
