veritas R8 panel flashing green light | on ElectriciansForums
Discuss veritas R8 panel flashing green light in the UK Electrical Forum area at ElectriciansForums.net
A
amcjam
Hi
Not a panel I am familiar with, but asked to have a look. It has green flashing led on panel system has locked out, battery flat and charging voltage and aux reading 24.4v with battery removed.
Did power it down to regain control of system, but readings were still 24.4v.
any thoughts
amc
Try powering down the system then powering up. ....If this doesn`t work hard reset the system by powering up whist holding rest button.....There is no way you are getting 24v on aux, the transformer is only rated at 18v
Reply to veritas R8 panel flashing green light in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
