Vertical Heated Towel Rails | on ElectriciansForums
Discuss Vertical Heated Towel Rails in the Australia area at ElectriciansForums.net
Sydney
Good day,
I would like to ask what the experience is on vertical heated towel rail installations as opposed to the heated ladder rails. What are the common difficulties you run into and is it more time consuming to install than the ladder rails?
To me, it doesn't make much sense, even though it does take up less space. I'm just curious, looking at installation instructions and the wiring of it.
Reply to Vertical Heated Towel Rails in the Australia area at ElectriciansForums.net
G
Dual fuel towel rail heating element The instructions with the new dual fuel towel rail we've had installed are in very bad English and, anyway...
GonisDowr
G
Have I confused you or worse frightened you away? The tests I described may quickly decide your question.
