Very Early type of Socket | on ElectriciansForums
Discuss Very Early type of Socket in the UK Electrical Forum area at ElectriciansForums.net
P
Peter J
I have seen a very early type of surface mounted wall socket, and it is now not in use. It has 4 flat pins, all horizontal, and they are set up as a cross with one at the top etc. A photo has been added.
It may have been imported into New Zealand in the 1900's but I could not disern the maker. It could have been connected to a 110v DC supply.
Peter J.
[ElectriciansForums.net] Very Early type of SocketHere is photo of socket, note Crabtree (?) switch.
got a collection of these Tony....and it wasn`t just crabtree that made em either...."landor".."clipsal" and "volex" made em n all......the one in the picture will date from the mid 20s..to the 30s....in fact, as far as i know they were making these until 1967....they have a screw on front with open contacts inside......
Thanks for that re maker and date. I thought it would have been earlier. I suppose it is rated at 10 amp. Have you seen a plug top for the 4 pin socket? Do you know why they had 4 'pins'? Polarity? or could be also used by only the 2 centre pins?
Peter J.
I remember a TV programme a while back, might have been Chris Barry, and it covered power supply pre-national grid. IIRC there were over 12 different types of plug fitments at various voltages, could be one of these but I wouldn't know where to start looking.
It looks like it could be what's know as a 'parallel and tandem' socket, designed to accept 2 different kinds of American 2 pin (unearthed) 120v plug, back in the days before people had made up their minds as to which standard to adopt; a bit like a VCR which will play VHS and betamax.
is the round bit in the centre a screw or an earth terminal? i've seen sockets with 2 flat terminals either side of a round E terminal. yours looks like it's designed fo 2 different plugs.
im really suprised that you dont know these ones tel. after all you were there to witness the transition from dry string to wet string, and then from wet string to cable. :wink_smile:
wet string, i understand. what is cable?
The ones your thinking of Tel were Wylex. Hollow central earth pin with two off set pins either side. The plug top would have a socket in it so they could be piggy backed.
that's the ones tony. bloody good idea. remember when we had our first telly, was 4 of them plugs stacked into the only socket in the living room. 1 for the telly, 1 for mam's iron, 1 for da's trouser press, and 1 for the standard lamp , coz you couldn't see the picture on the telly with the main room light on..
Reply to Very Early type of Socket in the UK Electrical Forum area at ElectriciansForums.net
