Very Good | on ElectriciansForums
Discuss Very Good in the UK Electrical Forum area at ElectriciansForums.net
Baker1988
Kingston Upon Hull
This morning i woke up to my work clothes still wet as the dryer was not getting warm still working and spinning just not any heat, so i thought i would just fix it my self and finish drying them so i go to unplug it and notice this:
[ElectriciansForums.net] Very Good
it had been terminated terribly and had all melted and even burnt the front of the socket, i bought it second hand so obviously they have changed the plug them self at some point but obviously they dont know what they are doing, the earth was not even connected or any thing.
Just thought i would share.
The only damage was to the plug.... and also you with wet clothes... :) Things could have been worse mate.
Hi bud,just injecting a bit of devil's advocate...it is possible that the plug top was,terminated ok,but has arrived at that state,due to several reasons.
It looks like a cheap plug-top,and the fact that your dryer was still spinning,indicates power was still on,just the element had failed.
I have written several reports,regarding incidents such as this,and there are,in general, several factors occurring simultaneously or intermittently.
Poor quality plug-tops (BS rated or not...),under-counter S/O encountering minimal use,maximum dust/debris,sustained high current usage (not discounting a possible increase due to non-obvious dryer fault)...
We would feed a fixed water heater,say immersion,from a fused connection unit,for this reason,when the load difference for a dryer,may only be a few amps either way.
A friend of mine,supplies and repairs white goods,and this issue is extremely common,not usually becoming more serious or widely known,as the new or exchange machine,comes with a new plug-top. It is only when the heat damage has spread to the S/O,that more work identifies the problem.
There are MANY more hidden household disasters,some i have witnessed,such as capped vents,on loft cylinders (over bedrooms),and DB's with fitted but bypassed RCD's,are far more worrying.
My pals grandad,when i was a kid,used to say we were "sleeping with the enemy",after inviting pressurrised water,gas and electricity,into our homes...and he was partially correct,as my experience ever since,has proved attaining 100% safety, to be impossible :joker:
If I were you I would have a good close look at the socket outlet that this plug has been in. The heat may well have damaged it. Daz
Reply to Very Good in the UK Electrical Forum area at ElectriciansForums.net
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
You made the mistakes of a) asking the wrong question, and b) asking it at all. If you ask them, then of course they'll gold plate their...
