Very low reading of PFC test | on ElectriciansForums
Discuss Very low reading of PFC test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
dhaval
hi,
I did Ze test, I got 0.22 ohms but PFC test I got 22 Amps. it is very low. I am expecting a (230/0.22=1045 amp ) by theory
So pls let me why it is very low reading
I'd try the test again as somethings not quite right. Did the earth lead from the test instrument have a good connection? Also did you try testing to neutral as this should give a higher perspective fault current than to earth? (unless if it's tn-c-s where they should be more or less the same value as the neutral and earth are linked in the service head).
Let us know how you get on.
Why? I've had loads of sub 1 ohm readings on TTs.
I bet they wern't fitted within the last 10 years! Are we going to get to here about your one in the middle of the house again Trev! :wink:
No, I was just making a point mate. It takes a bit of work but it can be done.
Oh, and some of them were done in the last ten years
I was only pulling your leg Trev :smiley2:
Reply to Very low reading of PFC test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have known some inverters to be damaged by insulation testing. as a general rule, i tend to avoid doing an insulation resistance test on things...
