Very odd problem what do you think ? | on ElectriciansForums
Discuss Very odd problem what do you think ? in the UK Electrical Forum area at ElectriciansForums.net
Dave OCD
Mentor
Cornwall
I might be overlooking something that's right under my nose but opinions would be much appreciated. I visited a customer today with a detached garage supplied with power from a 13a RCD fused spur in the conservatory [spurred off RFC].
The RCD is 'tripping' randomly so I went to investigate.
The unit in question must be around 15 years old or more and immediately I found that the test button did nothing, a test at a garage socket also failed at x1 and x5 and the RCD refused to operate and I then found the same with the load disconnected testing at the spur itself. [SFCU in case of pedantry:)].
So after isolating and doing an insulation resistance test at 250v with everything switched on in the garage [freezer and lights] which showed around 40 Megohms L-E & N-E I fitted a brand new BG Nexus RCD SFCU, upon powering up the test button worked perfectly but in the garage both my tester and Kewtech plug in socket tester are showing L-E reversed ! :eek:
With the supply and load cables connected together everything is fine [Highest Zs is 0.79 at the furthest garage socket].
So I have another replacement unit to fit tomorrow, it has to be that, right ?
I can't think of anything else which could cause this but opinions are most welcome even if I'm being dumb. :)
Sorry about the long winded tale !
Hi - I was just going to suggest to check through the installation earthing. Perhaps a wander lead from met to that outlet so it's 100% that earth is where it's supposed to be :)
Thanks Wilko, yes I'm certain about that, with the new spur in place the garage lights wouldn't come on either. I'm 99% certain it's a dodgy unit but doubts creep in as it's brand new and I can't see how the internal circuitry could create this. But if I'm right it's a very dangerous RCD. :eek:
with the RCD out of circuit, then test for polarity. if it's right then then it is a duff RCD. dangerous and should be brought to manufacturers attention in case they have made a faulty batch.
That's exactly what I did Tel, I know it has to be the RCD but it just seems so odd. I have another to fit in the morning so will update tomorrow, thanks.
Reply to Very odd problem what do you think ? in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
Im not as clever as you guys. I would be doing what somw others have said, I would be leaving certain items switched off for a period of time...
