Discuss Vfd for well pump in the DIY Electrical Advice area at ElectriciansForums.net
@Rob, you are up early mate...
I'm not in the UK timezone.
The OP dependent on what he wants to do, could connect the sensor direct to the drive without the need of a PLC and use the drives inbuilt PID or basic logic functions.
It's a really common set up for pumping systems/LEV systems.
Just to keep the pressure at 60 psi
It’s a Allen bradly drive I have, just wasn’t sure if there’s setting in the drive to say run and keep the pressure sensor reading 60What VFD are you thinking of using?
As above, why not feed the signal from the sensor directly into the drive? Why the Allen Bradley PLC?
No there is no plcThat makes it more clear. The VFD is Allen Bradley and there is no PLC.
Reply to Vfd for well pump in the DIY Electrical Advice area at ElectriciansForums.net
